Tim PloughNman Daley RIP
I am a Ford guy but also a Ferguson nut as well. I am researching the wheels used on the TE and TO 20 Ferguson Tractors. Ford used the 3 x 19 front rims with the 4 x 19 single rib tires. Are the Ferguson front wheels the same as the Ford 8N bolt pattern? The back wheels were the famous 'hat rims' used from '39 thru Hundred Series production, size at 28 x 9. The tires were 10 x 28 but they measured differently back then and they are now the same as the 11.2 x 28 tires. Does the Ferguson tractors use the same rims? If so, then they must have used the same supplier. Kelsey-Hayes was the original supplier of wheels/rims, both front and back. I know Ferguson 28" center discs on the rears are scalloped but is the bolt pattern the same as well?
Ford/Kelsey-Hayes 9 x 28 Hat Rim & 8N Center Disc -
Ford/Kelsey-Hayes 9 x 28 Hat Rim, stamped logos -
Ford/Kelsey-Hayes 3 x 19 front wheel for Ford 8N -
Tim *PloughNman* Daley(MI)
