grassrootsfarmer
I have ordered a new starter switch for my TO-20 Ferguson, Sparex part #S42538, which I read should be the correct replacement. (This switch is a gear-shifter activated.) In removing the old and probably original starter switch, I see that the connecting brackets, where the clevis pin connects the switch to the gear shift rod, on the old switch are much longer than those on the new. I am waiting for the new switch to arrive. Has anyone had the experience or replacing the old switch with a new one? I am hopeful that this is not going to be a problem.
I guess if it doesn't work I will simply buy a cheaper starter switch which looks like it mounts on the dash.
This latest mess is getting expensive. I think the switch shorted out and then boogered up the starter which drained the battery!!!
Good thing I have another tractor.
