inputshaft removal need help
mcciodirk
New User
Hello, i need to remove my input shaft to renew the seals.
but after reading allot of tips and tricks i can not figure it out. lower shaft in or out. sirclip removed or even removeving the complete gearbox....
i have some pictures and i hope if some body looks at my picture they can tell me what to do.
[/url]Fe35 ingaande as-3 by Dirk Wegman, on Flickr[/img]
[/url]Fe35 ingaande as-2 by Dirk Wegman, on Flickr[/img]
[/url]Fe35 ingaande as-1 by Dirk Wegman, on Flickr[/img]
Richrd is trying to tell you the serial number you gave- and engine code, is for a 1962 MF35. Your photos are labeled FE35, a generation earlier British model.
Your pictures show you ain't half way there. the seals go in and come out from the transmission side of that bulkhead. So the gearshift cover and almost everything inside has to come out... and go back in to the exact same spots... you got the manual? And check out people who did the same job on you tube...
To remove retainer that seals are in you have to remove snap rings. In #2 picture there
is two snap rings. When you do this then remove outside round plate(??) housing. Not
sure the correct name. Then the shaft will come out a little and the gear will drop
down. This lets the gear drop down from gear in retainer housing and then it will come
out. When remove there is two seals in retainer. You have to take it apart to replace
the two seals.
nice book!
can you tell wich book this is? and perhaps where to get?
And i think iam going to get it. i have removed the lage clip... but next to remove the small clip. then need to screw in two bolts to remove the bearing holder.. yes?
then the axle inside will drop a bit. so i can retract the upper housing out.
is it a 62? oke... i thought it was a 57. I live in the Netherlands so its probably a British one.
Massey Ferguson:
Technical service Manual:
NO:
FORM NO: 1448 811 M1
Part 6
Group ll
Section B
Part 1
Pages 1>15
Now lets see if Sample PICTURES upload:
(quoted from post at 22:45:01 10/24/16) Massey Ferguson:
Nice pictures in this book. Gave me some help. Found a manual on ebay.
At the moment i managed to remove the lower bearing holder. Now i can see the inner clip.
The shaft wil come out to the front?
