Toora Stephen
I am nearly fed up with this. A few weeks ago I replaced the head gasket in my TED20. It ran fine for a while after that, but before long there was evidence of water in the oil and the engine again.
I retensioned the head last week. The water caused some trouble starting, but then it ran well for a while. Now it is so wet it will not start without hours of coaxing and when it runs it spits smoke and seems to be running on 2 cylinders.
When I replaced the head gasket, the old one looked pretty new - so someone had tried the same thing not too long ago.
Is it possible there are cracks in the head or the block that I can't see?
Could the water be getting in past anything other than the head gasket?
Should I give up and just buy another tractor?
- TS
- TS
