Hello.I have a TO-20 with some electrical problems.This tractor was converted to 12 volts years ago.I was having trouble getting it to start and went and cleaned all the electrical connections and grounds and now when I connect the battery cables the starter begins to turn with the key in the off position.I installed a new ignition switch and a new starter solenoid and rechecked the wiring several times and still get the same results.I've taken the starter apart and it looks okay inside.When I jump it with cables it spins normally.When I check the cable that goes to the starter with a test light while the starter is off,the test light lights up when I turn the key and goes out when released but when I install the starter and hook up the cable the starter turns instantly with the key in the off position.If anyone can give me any idea of why this is happening I would appreciate it.Thanks.
