Hi all.
Newbie here bought a TE20 for light work around the smallholding and just to play with. (believe it is a TED20 with 85mm 4 cyl gas/evaporation oil engine.)
It runs OK - timing is all over the place which I put down to wear in the gear driving the distributor and the governor system - I hear no knocking noises etc and it seems to have decent power. Little bit of blue smoke when starting but that goes away soon enough. Starts first time every time.
Thing is it shows NO oil pressure. ZIP.
I bought it from someone who is a car enthusiast and he claims to have done some refurbishment (basically cleaned it all and went through it). It does look good and all seems to work except for NO OIL PRESSURE!
I had 15W/40W multigrade and then tried 40W grade. no change.
1. I checked the gauge and that works - I removed the pipe from the oil rail and pressurise the pipe with air and gauge shows pressure more or less correctly.
2. I checked the pressure relieve valve at the filter to see if it leaks through perhaps - but no, all is well.
So now I believe either I have worn bearings etc or the pump does not work, or there is a crack somewhere...
I plan to drop the sump and then check clearances on the mains and big ends -but I am sure bearings worn to the point of NO pressure would make loud knocks etc when running.
Any suggestions on how I can check if it is the pump, or perhaps can one pump oil in from where the filter normally feeds the rail and see what is going on?
Is there anything else that can cause this (oil circuit to the cam shaft and to the timing gear?) that those with experience can suggest?
Any helpful suggestions much appreciated.
