Year of a Ferguson and a little info
Hi. We have a tractor on our farm that has been here since new. It was my wife's Grandpa's. It's a Ferguson and it's serial # is #TO-116674. I'm assuming it is a TO20. Am I correct? Could anyone tell me what year it is? Also, I want to replace the wiring bit by bit. Right now I'm looking at doing the wiring running from the coil to the keyswitch, etc. It looks like it may be 10AWG. Would I be correct? It is a 12 volt tractor. Thank you in advance. Brace yourself for many, many questions!
The wire to the coil can be 14 to 16 gauge. That size will be sufficient for all the circuits except the battery lead from the alternator/generator, that one needs to be 10 gauge.
Use stranded, low voltage automotive wire, solder and heat shrink all connections (tape will eventually come unraveled). The split black plastic harness maker works well. Not original, but makes for a professional job.
