Bullfighter
New User
I was wandering if anyone knew where a tech article is the change the pto seal on the to 20, And where would be a good place to buy one at? Mine is weeping some what. And does any one have a used grill or hood for a to 20. Ive only owned the Fergie for a week but I love the little tractor and will probly always have it even if I go bigger. Thanks for any help
You can drain hydraulic oil or park tractors front lower than back to change seal. I park mine on side of slope next to shop. Take the 4 bolts out around the pto. Then housing has square shoulder(I use large channel locks) on side and turn this to loosen (if its stuck) and pull shaft out.It just slides out no threads. Change seal and O ring.Replace shaft and you can turn shaft to line splines up as it goes back together.
Just did mine. Rear wheels on wheel ramps. Drained about 5 litres of oil out of drain plug under pto. As said pull shaft. Replace seal. Buy through parts from bare Co or sparex.
(quoted from post at 18:29:16 10/09/16) Without knowing where you are this site that produces this great forum does sell the seal also.
PTO seal
Thanks everyone for the reply. Im reallt digging my fergie and how simple it is. Ive already ordered 12v conversion and electric ignition. Gonna tackle the seal once i get done. Thanks
