Had to replace manifold
FergySGM
Had to replace manifold due the right side being broken.
Wondering if there is tightening sequence for the bolts and if
there is a torque specification for them. Also looking for the
red tail light for the 55 TO 35. Any suggestions?
INFO from the ARCHIEVS:
JOHN (UK)
Manifold nuts are 25 - 30lbs ft.
It only shows flat washers in the parts list, but I don't think that it will matter if you did use Spring washers too if you wish. Yes the studs could be difficult, as long as they have no stripped threads and tighten up, leave them. Use new nuts by all means. Just make sure that all the old gasket is removed from both faces and that the manifold surface is totally flat or it will not seal properly. John(UK)
Sequence for tightening is very simple , start in the middle top and bottom then diagonally to the next set upper and lower , finally opposing diagonals as before for the outer nuts .
I use brass nuts that don't seize up so easily , they do need retightening from time to time .
