To20 Radiator
Roger D.
New User
Hey guys i'am about ready to switch out radiator's on my to20
and was going to replace the mounting bolts. does anybody know
what size bolts are needed and what kind. this tractor is about
80 miles from me and i'am just trying to save a headache before i
get there. thank you
According to the TO 20 manual it is showing 7/16 X 1-1/4 NF carriage bolt. Along with a 7/16 lock washer and a 7/16 NF nut. I believe there are two of each item for the radiator to be held in with.
What he just said and I believe some rubber mounting pads to slide the hardware through to dampen out vibrating metal wear.
There is a radiator bolt mounting kit on the Ford 8n parts catalog on this site. They also have the rubber pads. These should fit the TO20 and TO30.
I'm sure someone will correct me if I'm wrong.
