Back in July I had a problem with overheating and changed the thermostat and antifreeze. I tested the thermostat that was in the 35 and it was only opening about half way so I replaced it and the antifreeze. Temp gauge always showed 200 plus degrees while bush hogging and thought it was because it was pretty hot this summer. Well I blew the head gasket. I realized it when I changed the oil and antifreeze came out first. I sent it to the shop and while it was there I was cleaning out the garage and notice the old thermostat. gave it a good looking over and saw the it was stamped 88 degrees C.. which is equivalent to 190 degrees F . The one I replaced it with is the correct one 160 F. Could that be the reason for the blown head gasket due to the thermostat not opening fully.
Heres a little conversion formula: Celsius temp times 1.8 plus 32 = Fahrenheit temp
