For all intents and purposes I have been calling her a TO-20 and the PDF manual I found online for the same has been true until now.
In ordering an oil pan gasket the item I receive is a couple of inches on the narrow side and is shy a couple of bolt holes on the back end.
The manual also states the oil filter to be within the pan but there is a course screen type thing surrounding the pickup tube which removes from the side of the pan as opposed to the bottom. On the side of the engine is where the previous owner pointed out the oil filter which is a diagonally mounted canister on the left side which unfastens from a long shaft which seats in the bottom of the said canister revealing a cylinder filter.
Does anyone know what model I actually have here so I can source the proper parts?
