Delawaresurfman
Poster earlier up in tractor talk board. To 30 generator. It's all original 6 volt. I had non starting issues. I got a new battery and still nothing. No click no nothing. Cleaned the wires new ends everything. Nothing. After reading I just pushed harder on the shifter and it finally starts now and again. It seems the saftey starter switch is bad or not adjusted properly if that is even possible? Looking at the part online I do not understand how the rod from the shifter activates the switch. Can anyone explain that? How does the rod attach to the switch? I do have the parts books and the service manual at home but the tractor is at my dads house. How hard is it to replace? Any issues with replacing it that I should know about? Such as the rod will fall down in the bell housing never to be retrieved except to split the tractor? Any tips would be appreciated thanks, John
