TO35 lube of front axle pivot bearing question
Napa has spray graphite in both wet or dry
Service tech said I needed wet, but I figured I needed dry as I thought the purpose of the lube was to use dry lube so it would not collect dirt
and dust to wear out the bearing,
Which should I use on this pivot bearing?????
