grassrootsfarmer
I have a 1952 TO-20 with a 6 volt generating system. I need to know how I know is charging. I just installed a rebuilt generator, new voltage regulator and new ammeter and finally got the tractor to start. The ammeter deflected initially back and forth to the positive side for a short time and then settled to zero. I used the tractor for about 3 hours with no movement on the ammeter. I rechecked all wiring and will tighten the fan belt a little this morning but it was already quite tight. Questions:
1. How much should the ammeter deflect when charging? My old system went to about 15 amps, I think.
2. How can I test the new components? I have a multimeter and very basic knowledge of things but can follow instruction
well!
3. If it ain't broke I guess I don't need to fix it. Just want to understand better what I am or am not seeing.
Thanks in advance for any help you can give.
well!
