Fisrt time to speak on this site. I get a lot of information here. Best as far as I'm concerned. I rebuilt the head (local machine shop) on my TO35 about two weeks ago. Everything fired right back up. Neighbors joke at my old tractor but it has a loader and everything I need. When I started it, ran great for the first few minutes then I started hearing noise.... Like low end noise. I QUICLY shut it off. I know the sound of this tractor. During that time no oil at all in the filter much less the head.
After hours of research I found it was likely the oil pump. HMMM. I dropped the pad. That was fun and pulled the oil pump. The set screw holding the shaft was gone. Scared the flat plate on the back of the pump. So I put the rebuild kit in my CART here at Yesterdays tractor and read up a bit more.
The bypass regulator is stuck and do not know how to get it out? How do you remove the plunger? the part below the screen. I think its stuck anyway. I just don't want to go through all this and determine the bypass is partially open or fully open. Has anyone done this before? Further I do not see that part on the rebuild kit.......
