I pulled apart the levelling box after grinding away the roll pin of the 1950s to dismantle the levelling box.
I had to cut the leveling box shaft just below the hosing to remove it from the housing.
The shaft will not screw down past the level mark on the shaft, I believe this is due to the slight bend in it.....
I was going to straighten the shaft then weld back together. But now that the shaft is cut its very hard by eye to see the shaft bend.
Wondering if i would ever get it straight enough to screw all the way down...
I know i can buy a new one, which is the way i was leaning.....but thought i would see if anyone has tried this...
