Not as bad as I thought
Armand
Just got the news, Its only a head gasket. Liners and rings are in good shape. There was so much antifreeze in the oil I thought it would be worse than that so I do consider it good news Here's a tip " forget the Bars Leak.". Dose not work so save your money. Also going to have the key ignition put back to factory spec. The previous owner had bypassed the safety switches which wasn't to smart on his behalf. I'll be back in the saddle again soon
Great to hear, congrats. Also it is good you are putting the ignition back correctly. Safety switch is a great item.
I totally agree with you on the ignition. When I first bought the tractor I learned that the setup wasn't to safe. The previous owner had put a remote trigger type hand held gizmo on it and it scarred the hell out of me....
