steve19438
so I looked at it on Friday. seems to be in better than average condition except for two things.
the neutral safety switch is not wired but the tractor starts without it. would this indicate a re-wiring at some point?
the tractor is a SGM model. two stage clutch, right? the pedal meets resistance 1/2 way down but nothing before that. with having the clutch pedal on the foot rest the PTO keeps spinning. no where in the clutch travel does the PTO stop spinning. the trans shifts ok, clutch does not slip but even with the pedal all the way down when engaging the PTO there is a bit of grinding.
am I dreaming to think a simple clutch adj. will solve anything?
thanks.
thanks.
