hydraulic pump removal
Trying to remove pump from TO 20 parts tractor, pto shaft is out, all bolts from bottom removed. Yoke is out. Is. There any thing else to remove? Could just be stuck gasket. But
wanted to be sure before I got to rough and damaged something. Can the complete pump be used in a 9N FORD? THANKS
Ford 9n, 2N. TO-20 and TO-30 all use same pump. You could always change the 9N to Ford 8N pump and top cover and get built in position control.
(quoted from post at 00:46:20 08/04/16) There is one small bolt on each side below seat. They hold pump. Remove and it should pull out.
You thinking of the TO-35 and later pump. TO-20's and 30's don't have those pins that hold the pump in position.
If you are talking about control fork when you said yoke then it sounds like you have everything removed. They are pretty straightforward. Remove pto shaft and unhook the control valve from the control fork.
