Ferguson help
Cubix80
New User
I am trying to determine what model I have so that I can order a parts and service manual. The reference number says TO-74487. I believe it is a TO-30 1954 MODEL, but I am not sure. Its four cylinder gas four speed with a start gear. The transmission says TO-501B. Any help would be appreciated.
If that TO 74487 was on the serial number plate between the steering column and the hood then you have a 1952 Ferguson TO 30. All the TO 30 Ferguson manuals are the same so you don't need a certain year. Look at the left of this page under Research & Info go down to Serial Numbers then follow through and you will see it is a 1952.
