converting to 12 volt
tractor12
New User
can some please tell me what to do? converting 6v to 12v everything is 12 volt but distributor which is 6v what kind of
resistor do i need between dis and ignition do i need? just
bought new 12v coil which is 2.2 ohms across plus and minus
terminals. thanks very much.............
:cry:
Distributor, points and condenser don't care if system is 6 or 12 volts.
Points and coil do care that current through the system is limited to about 4 amps to prevent burning points and overstressing coil.
Normal 6 volt coil should measure about 1.5 ohms across primary, direct 12 volt (no resistor required) usually measures about 3 ohms across the primary. A 1.5 ohm resistor can be added between ignition switch and coil input to give 3 ohms total on 6 volt coil in 12 volt system.
Your 2.2 ohm coil poses a puzzle as it is in between 1.5 and 3. I suspect you may not be adjusting for some resistance in the meter probes. Short the meter probes together and check the reading, then check across + and - on coil. Now subtract probe reading from coil reading and this will be actual coil resistance. I suspect you have a 1.5 ohm coil and are seeing some added probe resistance. If so you will need an added resistor of about 1.5 ohms.
