Hi again.
Ok i need to replace one of the skid plates on my slasher. It is 10 mm thick steel being welded to thinner steel.
here is a pic
the side you see is the good one the other side needs replacing
I have access to a 240 cig welder that takes 2 or 2.5 mm rods. Will this be able to weld 10 mm steel, even if i do it in stages. I am a novice welder
here is a pic
