Delawaresurfman
Well it's been months ago that I ordered a new manifold for the cracked one on the 1951 TO-30. It is new to me, was my Grandfathers and has
been in the family over 50 years that I can verify. I also ordered all new intake hoses, radiator hoses and thermostat, along with other parts.
Tonight I got around to starting to fix it. I started to remove the hood as I also have a broken radiator bracket that needs soldered. The first bolt
came right out. The second one just spun and spun. I see now the square nut has a sheet metal holder for the nut not to turn. The first side
was rotted away and I put a wrench on it. Guess I gotta cut the sheet metal away on the second side to get a wrench on that one.
I removed the gas tank to access the manifold bolts. Fuel line disconnected and it came right out. I'll rinse it out now that it's off. Manifold bolts
came off with no real issues. Some with a socket others with a open end and box wrench. Two studs unscrewed from the block, no problem I
have all new studs to reinstall. I'll reinstall everything later in the week. I need to modify by grinding a few wrenches to do the install. Man it's
tight in between the webbing. Removal was one thing but torquing them proper is another.
The head by number 4 is lightly pitted just as I expected from reading on this site. Nothing too bad a gasket will be fine. Total into it now is
about 1hour 15 minutes. Really a easy job with caveman tools.
Thanks for everyone's advise and the excellent reading on this site. I'll update more later, John
