bobbyj0908
So, I take it upon myself to rebuild the carburetor from my "54 TO30 and what fun I had doing it. I purchased a rebuild kit, disassembled the entire carburetor, removed everything from it that I could, bead blasted the outside of it, put a nice coat of primer on it, installed all new hardware from the kit following the instructions from a video on the interwebtube. Since re-installing the carburetor and adjusting the linkage according to the shop manual, the motor starts and runs but only at high RPMs. I have adjusted screws and linkage and nothing slows it down. It is either high RPMs or off. No in-between. It does smell as though it is running a little rich. If I adjust the large screw on the front of the carburetor I can get it to shut off but not slow down. Any suggestions/hints/ideas would be greatly appreciated.
