Acid damage repair
Need to repair the steering box where a battery leaked for quite some time, at some point before I bought the tractor.
I've considered both JB weld and 2 part epoxy. Any considerations on these two ideas, or any other suggestions?
Don't even consider having it welded , it either won't work or the heat will ignite the high magnesium content alloy and you will have a pyrotechnic display in the garage .
I would try to get a replacement , otherwise the epoxy filler used to fill scratches and gouges in hydraulic rams might work .
This may actually cost more than a decent spare part .
