Hi Guys i have the radiator off the tractor. Went to undo the drain tap at the bottom as it is seized so not much use for draining water.
Undid the bolt on the tap that holds it in the bottom of the radiator and whatever it threads into has broken. So the tap is loose but will not come out... Anyone come across this.
I am thinking I will cut of the tap and probably drill out the broken bits and either block it up of retap it??
