Helping my grandson repair this tractor and trying to determine the correct model. The serial number found under the steering wheel and above the throttle is
TO-53705. It does not fall under any of the 6 models listed. When he got the tractor the battery had been changed from 6 volt to 12 volt. After leaving the ignition switch on and burned all of the wires leading to the switch, voltage regulator, coil, and distributor. The nut holding the wire on the distributor was corroded that it would not come off. Finally the stud turned inside the distributor and broke the insulator that the points connected to. This tractor has an extra feature on it that allows the tractor to move very slow when doing ground tiling.
Any help in identifying the model would be appreciated.
Thank you
Thank you
