4on-the-floor
Power steering pump problems again. It quit working about three years ago and i replaced it with a used one , worked better but not real good. So i bought a new one that was listed for the 1959 TO-35 with the Continental z134 engine. It bolted up but was tight against the dist. cap so i was unable to remove it, sent it back . The problem was the fill tank had a cap bolt in the center of the tank . On mine it is off set a about 1 inch moving the fill tank towards the front of the engine and leaving more room next to the dist. Question is , does any one know if the old fill tank will fit the new ones ? Or where can i get one like mine ? Last question , can a different style of pump be retrofitted to bolt up and work
I tried to upload photos but i don't see them.
Thanks JIM
Thanks JIM
