miner09
- Location
- Pattonville Texas
Well got the assembly off. Let it soak several days with brake fluid around all bolts.
One of the bolts that holds the water pump is a stud that goes thru assembly housing. You can see three hole in housing.
It was rusted holding housing. This one was on junk motor. Now to take one off engine
that needs new gasket.Hope this helps someone that has to replace gasket. I never change them as it usually don't give trouble.
