Rear Main Oil Seal
Having trouble finding the right part for my Ferguson TO20.
I was told I need a new Rear Main Oil Seal. Behind the flywheel is crank shaft seal.
Im having trouble understanding which is the right part on this site or any site to order.
Can anyone help guide me in the right direction?
Thanks in advance.
I believe that is the same part just two names as it seals the rear main and of course rides on the crankshaft. Tractor needs to be split, flywheel comes off and oil pan off. There are two bolts to be removed from inside the rear of the block and the other three you see when the flywheel is removed. Please remember that the open end of the seal always goes toward the oil source or inside. Not a bad day, or weekend job..
Check out the video of a TE
https://m.youtube.com/watch?v=ifwXt6a4Efg
Thanks Tom H. Fortunately I am having a professional do this for me, as it's a bit beyond my capabilities. The person doing it asked me to order the pet as he does not have Internet. Based on what you know, which is the part(s) I need to order for him to replace this seal? Thanks again for the help.
Have you ordered a gasket set to rebuild the engine? If so the kit will have seals in it. If the kit didn't have seals in it for some reason the rear seal # 1750112M1--1750216M91. This number will help you get right seal from supplier. The gasket set from this set should have what you need.
Lucky you. As miner stated order the parts here. Get the full seal kit which has the rear main gasket and seal, $20 and the oil pan gasket.
