sediment bowl assembly change
(quoted from post at 18:58:59 05/25/16) I just changed the sediment bowl assembly on my to 35, no fuel in it. Does this have to be primed somehow?
It's working just like it should. Open the valve, give it some throttle, and start it up, and the bowl will fill up.
If it's empty, it's not leaking, and carb and fuel line are tight - and that's good!
It won't fill until there is a demand for fuel by the carb.
Start it up, let it run a few minutes, take it for a drive. It will fill on it's own.
