massey fergusson-35
can anyone tell me if a 6 ft finishing mower is to much for a 35 gas tractor? also are they a little weak in the pto shaft? thank-you
I think it would be a good fit,
I do not believe the pto clutch is weak, on this model tractor
of course before you buy any tractor, you should give it a test run if possible, would be great if you could hook it to a rotary cutter and get it out
in some heavy grass,
If the grass is to heavy, My little TO 35 wil bog down the motor, no pto clutch slipping
