Anonymous-0
....My old Fergie isn't getting gas to the carb. I've taken the line off and blown it out several times. I've taken the sediment bowl and shutoff valve unit off and have cleaned both filter screens and have blown it through several times.
I can take the line off of the shutoff valve/sediment bowl and gas flows fine. Reconnect the line and remove it at the carb.....no gas.
I have run a temporary line from the valve to the carb. No gas at the carb....
The filler cap is well vented and I have removed it and tried with the same results.
What's happening here?
