Hi All
Being reading over post with people with similar problem.
Mine backfires when i deaccelerate. I have done compression test they are within 5 psi of each other, so recon no bad valves.
I have static timed it, it ran worse, like this not matter where you have the timing it backfires and seems to change a bit
I have had a dwell meter on the distributor. The dwell stays constant while revving, which is what it should do i believe
BUT i can turn the rotor back and forth in the distrubutor, but it does not spring back to the centre, Is this normal or should it spring back. Lucas 34A distributor. As i want to make sure the advance is working correctly.
Next is condensor then coil. from what i have read it sounds like an electrical problem.
