Hi Ya
Pulled the front axle apart as the axle spindle is loose in the housing.
The bushes need replacing but the shaft it is also worn, so looking for diy ways to build the shaft up or sleeve the shaft or install larger bushes to remove the slack in the front axle.
Doesn't not have to be show room condition just want to remove the slack in the axle.
Throw me your ideas :shock:
