TO-30 PTO sleeve?
pomester
PTO bearing was bad, ordered a new one from here, along with a seal and the sleeve that presses on the shaft behind the bearing that the seal rides on -
Got the pieces today - bearing fits fine, but the sleeve is too small to press on - it's a Tisco 9N735B sleeve which seems to be what is commonly available for this application - it has a smaller inside diameter than the one I removed (original pitted and grooved) -
Anybody had this experience? what's the answer? where can I get a part that fits?
Well....first thing is the 9n735b is a ford part for the 9n.
The Agco part is 181183m1, which is no longer available...but does sub up to z1191, which is available from Agco.
I would think that this wrong part number is most of your problem?
Hope this helps, Wayne
thanks - I'll check out the Agco piece - I've looked and found several places interchanging the 9N735B and 181183m1, including our host -
I'd like to be using this tractor, and here goes another week - I knew when I started it was going to be hard to find a place to stop and finding parts has been more challenging than I anticipated -
thanks again
David
David
Let me know what part numbers you are having trouble finding...maybe I can help.
I have some new parts for the TO tractors.
Wayne
thanks - at this point I lack only this pto sleeve, numbers above, and a transmission cover gasket, 181514m1
the cover gasket is not a big deal as I can fabricate one, but the tractor is not going anywhere until I come up with a sleeve -
David
If you can take that sleeve to a machine shop with the shaft they can size correctly for you and press it on. I recently went through the same
issue myself.
I took a 40 mile drive to the nearest MF dealer - after I had ascertained he had a sleeve - $28.60 - bit it's installed right now - rainy day tomorrow, if the carb kit comes maybe I can have this handy little tractor back - I didn't realize how much I used it until it was disabled -
