graham_in_NJ
Hey Fellas,
Got my draft control assembly outta the TO-35. Not so bad, lots of heat and a big hammer. Need a new nut for sure, Now....how do I remove the clevis from the threaded rod? I can grab the clevis, but the rod is within the spring. The cup at the end just spins since it is not attached in any way.
It'll likely require rust-bust and heat....I just need to be able to turn it!
Thanks!
Thanks!
