so - the three point lift arms on my TO-30 are in the up position and won't descend - if you grab the arms and lift, they'll go up a bit and you can shake and the system is loose, release them and they hit a solid stop about at the top of the normal travel -
any suggestions on proceeding? - I got this tractor 3-4 years ago and the 3-point worked - I don't use the 3-point much/at all, I use this tractor to pull wagons and trailers - one day I went to use it and found it in this condition -
I appreciate any feed back -
thanks
David
thanks
David
