Any chance the lift lever is creeping up? Could be you just need to replace the cork friction disc. Also check the adjustment that is described in the manual for setting the lever.
If you have the top link adjusted out so that it is too long the draft control will lift the implement. Make the third link shorter and the issue should go away.
It seems to be creeping up while using. I don't have a manual for the tractor but appreciate your help and will look into it.
