Hi all
OK finally gettng aroud to fixing my brakes on the tea20.
They work if you jump on them fully. So pulled the drum, and as i thought the linging and drum are greasy. Its not full of oil but the bottom section is oily where oil is leaking in. There is no oil marks on theinside of the rim while looking at the inside of the wheel.
So i assume this would be a case of replacing the seal on the axle or gaskets??
From what i have read it looks like a job, to remove the seal you need to remove it from the housing and this means removing the axle. ( is this correct)
Have read that the sure seals will work. if i have the right axle. ( need to check that out)
I read that John (uk) had a documented procudure, Does anyone have a copy they could share.
Cheers Chaps
Cheers Chaps
