Hi
Ok we all know to pull you need to do it from below the axle so you dont end up on your lid.
Watching some u tube vids for using mechanical advantage(pulley setups) to pull stumps. this setup looks like there is some investment in the pulleys etc needed and complicated, but impressive video. https://www.youtube.com/watch?v=bRTIwWUg4fc
Also this vid, which seems like a easy setup. I am guessing stupms are easier to pull out in an upwords direction than across. but in this next vid will this change the pulling direction on the tractor so more likely to lift front wheels.
https://www.youtube.com/watch?v=pccuAUNwfw8
Also this is a good vid for comparision.
https://www.youtube.com/watch?v=bRTIwWUg4fc. fast forward to the good bits as he rambles on tad
what i remember from physics is that using the pulley setup would put less puliing force on the tractor than the single pull method.
Pete
Pete
