TO 35 carburator spring
S/C BOB
I am needing the float spring for my tractor sometimes gas just runs out the breather tube. Carb is clean too that float needs that little
helper spring. Anyone got a clue where I can find one. Thanks
There are two different spring types. One is a regular "pull" tension spring with two hooks on end.
The other is a torsion spring. Would have to know which one you need. I think I can get either one.
Wayne
It is the torsion square type spring I think...Wahoo I sure would like to get her fixed...Thank you my ph number is 423-360-5153
According to my information...your serial number of your tractor should be 175639 and above?
I am located in Canada...you are in Tennessee?
I will see what I can find.
Wayne
I believe I can get you this spring.
Can I get you to E-mail me at the button to bottom right of this message (Classic view) button should read...send E-mail.
Wayne
