Eric in Sonoma, Ca
I've just made the following upgrades
6 V positive ground system
New battery
New 1 gage battery cables
Rebuilt starter motor
There is 6 volts across the connection between the starter motor cable and the negative battery cable. At this location a Multimeter shows a connection when the starter switch is engaged
Motor does not turn over when the ignition key is on and the starter switch is engaged.
What is wrong?
New battery
What is wrong?
