Pump Support Pin T035
Hey Fellas - my pump support pin is leaking and I need to re-gasket it. If I remove it to do so, do bad things happen inside the trans?
Thanks!
It just fits into a hole in the side of the pump. If you are taking only one pin out, the other pin should keep the pump aligned and you should be able to just put the removed pin back in with a new gasket.
Dan
