Tom Bowman
Pulling fence posts with drawbar and chain, so nothing hooked to the top link/draft control spring.
I would push the lift control lever down to hook on the chain, and the lever (and lift arms) would raise on their own, while I was working.
Do I just need to do the quadrant adjust procedure described in the manual? Is this something the cork friction disc is supposed to fix? (The draft control spring appears to be adjusted properly, per the manual.)
