So I've recently done a bunch of work to the TE20. Reseated the heads. Cleaned it inside out. Put it together last night and worked a charm. Just have the rad to put on. No backfiring. No spluttering. Was great. This morning I went to try it and the starter got red hot (like it does when the battery is flat). Charged battery. Great. But it still wor start.
It turns over like it should with no problems, but it's throwing gas out of the carb/manifold gasket. Ive adjusted the carb (Zenith 24T) to specs. Slow running jet to 1 turn out. Main jet to 1 1/4 turns. I don't have the choke on at all.
Any suggestions as to what it may be? Nothing changed in 8 hours and it's doing this!
Thanks in advance.
Thanks in advance.
