1959TO3523c
New User
I am new to this forum. I just purchased a 1959 TO35 with the Standard 23C diesel. The injector pump was frozen up so I purchased a rebuild kit and pulled it apart as far as I felt comfortable with. The pumping plungers were not moving as well as one of the rollers. After days of spraying with oil and smacking with a rubber mallet they seem to be free. I am not sure if there is any issues with the passages the plungers slide in since I could not get the two bolts holding the drive plate on, I was afraid I would twist them off. I also did not disassemble the governor weight assembly and it seemed to have a lot of slot in it, is that normal. The two main questions are the end plate on my pump is like the one in the picture below and I can not find any information on rebuilding it. It seems to only have a filter screen in it. The kit has all the parts for the regulating valve which mine does not have. Anyone know where I can get the information? 2. How does the fuel filter housing come apart. It appears as it should screw off but I don't want to mess it up. Any suggestions?
