f40 single wheel colors
willowbk
Hey guys I'm putting together a f40 single wheel front end tractor. I can't find many pictures and I was looking for some input on the front end parts. Specifically the yolk that holds the tire. I would assume the rim would be bamboo beige. Thanks for any help.
I've got a picture here in a magazine that shows the yolk the same color as engine and tranny. The rim and hub is the same as the tinwork. I'm having trouble loading pics or I'd send it on.
Yes hub-wheel is bamboo and yoke is flint gray. Do you have a tire that is the right size? 7.50 X10 The China tires are under size, not the same as American tires. Makes the front of tractor to low. Don't look right. I'm using a Good Year that is old and has weather cracks but is the right size.
thanks miner, I do have the original tire but hoping to replace it. would look a bit silly if everything else is mint. Thanks for picture, I thought that was the color scheme. I will post some pictures later this year.
If you find a tire that is right size please post. I sent the one back in picture and haven't found a supplier. Maybe at a show this summer. I can find aircraft tires but would like to have 3 rib.
ya no mister miner 49er, you might have to ask this on other forums.
60's & 70's Farmalls, big trike Deeres. M&M's, a lot of off brands had these big front tires- I suppose balloon hay and corn wagon tires for squishy ground would be 5 or 7 rib? But I would shop thru those pages too.
That little tire looks like a 7 inch, I doubt it would hit the beads.
Both tires are 7.50 X 10. Well maybe when nnalert gets all the factory's back on US soil
we can buy the same tire that I've got. LOL If you see one on your way down this week
just buy it. It should be worth a case of Shiner.
