Okay so I have been working on our family's TO30. I replaced the sediment bowl and rebuilt the carb and it ran fine. Well after a week if the fresh new gas sitting in the tank all the crud broke loose. We had the tank boiled out replaced bowl again and I've had the carb off three times now because it will only run on full choke. After the third carb teardown when starting the tractor it was knocking something awful when starting and eventually wouldnt even turn over. I have the heads off and the oil pan and do not see any visible damage. The engine turns by when moving the fan blade(belt is still attached). anyone got any suggestions for me.
Thanks Phil
Thanks Phil
